208 slip yoke kit?
Discussion in 'The Garage' started by gotmud77, May 18, 2004.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    Has anybody used or heard anything about the sye kit from Arizona drivelines? The standard kit runs $400 and that includes a driveshaft with a cv joint at the top. I comes with a flange mount that gos into the transfer case. The only thing that i was not sure of is the hole that needs to be drilled into the main shaft of the transfer case. /forums/images/graemlins/dunno.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    don't have it but its junk. Like you said, just drills into the tailshaft. Aka you actually lose shaft length, rather than gaining, and there is no bearing support like there is with a 241 SYE kit. Only REAL option is taking Dodge components and upgrading. I just swapped for a 241 since kits are widely available.
  3. gotmud77
    Aug 4, 2003
    689
    bellefonte
    This company also has a slip yoke shaft that has a cv joint at the top that eliminates the vibrations. What do you think of this product?
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    people around here have them. Its a good idea if you don't plan to be hard into suspension travel and all. If you do look towards SYE on a 208 or 241 or if you want change to a new Tcase.
  5. offroad87
    offroad87 Registered Member
    Feb 2, 2004
    57
    Atoka, TN
    my slip yoke cv shaft from AZ driveline will be here in about a week ill let you know how it works out.
  6. gotmud77
    Aug 4, 2003
    689
    bellefonte
    great i will wait and see what you can tell me. I am running 8" of lift on my k5 and i need to do something.
