208 slip yolk eliminator?
Discussion in 'The Garage' started by durantk5, Apr 23, 2007.
  1. durantk5
    durantk5 Registered Member
    Mar 1, 2005
    50
    Greensboro, NC
    Does anyone know if someone makes slip yolk eliminators for a NP208? I am currently putting one tons under my K5 and would like to get a longer driveshaft in the rear to help with the angle. thanks, Nick
  2. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    Yeah,use the back case half and shaft from a Dodge 208.I know a guy who probably has it.
  3. Taylor
    Taylor 1/2 ton status
    Jul 17, 2002
    326
    Elizabeth, CO
    I was looking into the same thing a while ago, Tom Woods is the only company I heard that makes one for the 208, but its a pricy way to go. I ended up finding a good deal on a 400/205 combo and went that route.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,074
    486
    Grand Rapids area
    Yes. I just found this! Tom Woods is offering a real SYE kit for the 208. They rework stock output shafts and cut down the stock tailshaft housing (meaning exchange + core charge). I am curious about the length of this setup. It is $570, but that includes a C/V driveshaft.
    http://www.4xshaft.com/SYE/208TransferCaseGMDesign-32Spline.html
  5. Streetgliderx
    Streetgliderx 1/2 ton status
    Jun 16, 2007
    287
    Tuscumbia AL
    i heard you can drill and tap the tail shaft and drill the fatory slipyoke and put a bolt through it
  6. Blue85
    Jul 26, 2000
    9,074
    486
    Grand Rapids area
    Yes, you can. Arizona Drivelines sells a kit to do just that (although nobody here seems to like them). It gets rid of the slip yoke, but doesn't give you the extra 5-6" of driveshaft length that a kit like the one above would give you. That's a big deal in a short wheelbase rig.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    rear 1/2 of dodge 208 will bolt on with a couple minor mods to it
  8. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    hmm thats cool. a rebuild kit plus chain is like 250 then a new driveshaft locally here is 500+ (it seems im getting ripped off compared to others on here) then my dodge case im buying for 100 bucks. it seems i would be spending the same. either way. id rather go tom woods though. not sure if i want to rebuild my 208 though now that ive gotten a little further into gathering parts for this.
  9. xanthias
    xanthias 1/2 ton status
    Nov 18, 2004
    195
    Houston, Texas
    They discuss it at the bottom of this page:
    http://www.arizonadrivelines.com/SYE_Kits_$375.htm
    No pics though.
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i went the dodge back half route, it was a piece of cake.
  11. Blue85
    Jul 26, 2000
    9,074
    486
    Grand Rapids area
    I don't know that the Dodge case route is a "piece of cake" (It does require some TIG welding of the back portion of the case) - the TW kit would definately be easier. It can be done cheap (I also got a junk Dodge 208 for <$100), but you still need a yoke and a driveshaft. I still did the whole thing for under $200, but there was a lot of time searching for parts. See my thread here: http://coloradok5.com/forums/showthread.php?t=100934&highlight=208
    The big question is what the Tom Woods setup sells for as SYE ONLY (no yoke or driveshaft included).
    With either method, you have to tear whole unit down to replace that output shaft. A rebuild kit is kind of optional. If your T-case is working well now, you may not have to replace anything. It's just the most convenient time to do it.
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    theres 3 different dodge cases i believe. I ended up using the chevy half but the dodge tail portion reclocked and tapped to get the oil passage all lined up.
