208 tailshaft silicone
Discussion in 'The Garage' started by rcamacho, Aug 14, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I've got a pesky leak from the tailshaft housing. I've tried Orange RTV once and a non hardening sealant a second time to no avail. I've looked carefully and verified no cracks and that the leak is from the main housing to tail housing mating surface.
    Any suggestions? Would it be kosher to use permatex hardening sealer or some other material?
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    i've got the same problem. my t-case im sure is low on oil now. you use atf in them right?
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Try some of the "Right Stuff" silicone sealer. IME no other silicone is even close to as good.
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    try cleaning the surfaces with a wire brush and some brake clean then coat the bolts and both sides of the gasket(you do have a gasket, right?) with permatex hi-tack and don't overtorque the bolts. do that it should never leak again.
  5. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I put the whole thing together with right stuff and she dont leak a drop. It works really well. GM has some really good stuff to but I am not sure what it is.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have had mine apart around 5 times before I figured out the trick. Use the Ultra-Black and make sure both surfaces are DRY, this is the biggest issue that happens. Once you put the housing on tranny fluid will leak onto the sealant and you will be doing it again. So make sure its DRY.:D
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I've used black and orange RTV multiple times with success. Like 85mudblazin said: make sure both surfaces are DRY before applying the sealant.
    Rick
  8. rcamacho
    Jul 1, 2004
    1,324
    WA
    Well, I tried again with Ultra Black RTV. I was only able to give it 12 hours of cure time before filling with ATF. So far so good.
    FYI, never use Permatex HPF - the ATF fluid completely dissolved it.
