208 to 205
Discussion in 'The Garage' started by xtrmjoe, Aug 4, 2004.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    what does it take to go from a 208 to a 205
    x-member, drivelines, 700r4 adapter?
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    You'll have to make the output shaft on the 700R4 look like a TH350 27 spline. Then you'll need the tcase, shifter, TH350 to NP205 adaptor, coupler sleeve, and driveshafts. The crossmember should work. Usually the best way to do it is to get the whole tcase assembley and driveshafts from the same donor vehicle. Your 700 will have to be disassembled to change the output shaft. In the kit you get a spacer and studs also.
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    all u need is the 205 itself... a factory th350-to-205 adapter... factory crossmember, and a $50 spacer to take up the extra tranny output shaft length. Presto, done.
    oh wait, you need a couple of shafts from HAD also. /forums/images/graemlins/grin.gif
    j
