208 to 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rollingthunder, Apr 25, 2001.
  1. Rollingthunder
    Rollingthunder Registered Member
    Apr 3, 2001
    15
    Slaton, Texas
    I have a TH700 and a 208 transfer case. I am wanting to swap the 208 for a 205. Will the trany and new transfer case match up or will I need some extras? And what change in abilities should I expect after the swap?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Well, for one, you are going to miss the low gearing of the 208! You'll be going from about 2.6-1 Low to only 1.96-1 Low...But, the 205 will last longer and take more abuse - maybe you should think about the Doubler setup from ORD, that's what I am planning on doing...
  3. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    You will need a 205 case and transmission adpater out of a K series with a TH350. Adavance adapters and ORD sell a adapter output shaft for your 700R4 to mate with the 205 .
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
  4. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Advanced adaptors and Fitzall both make the output shaft for the 700R4. The correct output shaft sticks out .875" from the back of the tranny. Advanced Adaptors price is right at $170. Depending on the type of 205 you get (slip or fixed) you'll need to have the driveshafts resized. Also, the tranny pan will have to be modified on the back right hand corner to allow room for the front drive shaft (can use a body hammer and reshape it or cut it and weld in a new section.
  5. sb7979
    sb7979 Registered Member
    Apr 27, 2001
    9
    Ohio
    Don't you have to tear the tranny all the way apart to swap the output shaft? Or am I mistaken? In that case the $170 shaft is the least of the problem, unless you're comfortable tearing your automatic apart.
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, the output shaft is the first thing that goes in and the last thing to come out. Its all the way back there.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Personally I think you would be better off calling Jesse at 530-872-5725and get yourself a slip yoke Eliminator kit and a CV 1/2 or 1 ton driveshaft and keep your 208. I like the 208 and 241 best. Yeah, they aren't bulletproof but are your doing MAJOR rock crawling?
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Let me restate something. There aint nothin thats bulletproof. Us Navy boys can break anything. LMFAO!!!!!
    Seriously though, just be honest with yourself and your truck. You will be loosing some serious low gearage.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've heard that you guys can break an anvil with nothing but a rubber hammer. [​IMG] [​IMG] [​IMG]
  10. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I use the 208 in my race truck and in my Jimmy. The Race truck has 600+/- Rear Wheel HP. The jimmy has a zz4 crate motor. No problems with either one. Just make sure you keep it full of fluid.
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '84 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '93 Chevy P/U 4x4 454tbi
