208 to 205
Discussion in 'The Garage' started by Mastiff, Nov 15, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I see a 205 T-case in the local paper for $50. Seems like a good deal. What does it take to stick it into my K5 in place of the 208? I really don't know much about this stuff. I have a TH400 trans in there right now, with an adapter to go to the original 208 from 1983. Is it a difficult swap? Would I need an adapter to the TH400? Maybe it depends on what vehicle this 205 is from?
    I could also swap it in place of the 208 on my M1008 CUCV, which also has a TH400, but came factory mated to the 208.
    TIA
  2. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I would like to do this some day so that I could run a twin-stick setup.
    I'm under the impression that you need the adapter and the correct input shaft. So I've always thought that means you pretty much have to find a 205 that was originally behind a TH400.
    Also from what I understand the 205 with the correct input for a TH400 is also the most desireable setup for the doubler kits. Which means they are hard to find and usually sell quick if the price is at all resonable.
    I'm sure if I'm wrong someone will post. I'm really hoping I'm wrong, and there's hope that I may find a 205 for my TH400 that's not too expensive.
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Like said above, you need a 205 that was behind a 400, and the adapter that should still be on it. If not, you'll need to buy an adapter, and also change the input on the 205, which would kill the $50 deal.
    I'm assuming this is a chevy 205... ford used them too, but they were driver's side drop. Not bad if you've got a ford front axle to use as well.
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks for the info. How about the shifter and stuff like that? Can I go from 208 to 205 without cutting the body sheet metal? Any crossmember issues?
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    You'll want the crossmember with the 205 if you can get it, or just make the holes a little bigger on the 208's crossmember.
    the 205's shifter will fit in the same hole.
