208 transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EDGE, Oct 22, 2000.
  1. EDGE
    EDGE Registered Member
    Aug 12, 2000
    42
    virginia beach , va
    I dug into my t-case today and found that the housing is cracked.I want to swap it with a 205 anyway.What years should I at to get the proper spline count so I can pretty much just bolt it in?
  2. Does your truck have a turbo 400,350,or 700r4 trannie?
    IF IT AINT BIG IT AINT BAD!!!!!!
  3. EDGE
    Aug 12, 2000
    42
    virginia beach , va
    700r4 with a 208 t-case on an 86k5
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    You need a 205 that was mated to a TH350. You will also need a shorter output shaft put in the 700r4. Advance adapters sells the shaft, it's about $150 or so. I believe that the 1972 or later blazers were the only ones that came with a TH350 and an NP205.
    There are other options, like swapping a fined splined input shaft into a 205 off of a manual transmission, but you will still need the adapter from the 205 that came from the automatic, so finding it all together is the best way to go. I did this swap last year, so if you need any more info just drop me a line.
    BIGJ
  5. EDGE
    Aug 12, 2000
    42
    virginia beach , va
    Thank you bigj.When time and money permits I'll look for you.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    BigJ, how hard was it to find a 205 that hooked up to a th350? Where did you get it? What was it off of? How much did you pay? Would like to do that someday, but with all the interest in 205's I imagine the pickins are pretty slim.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  7. BIGJ
    896
    Central Arkansas
    Well, it just so happened that my friend had a 72 blazer with a th350/np205 combo. He dropped in a SM465 and t-case out of a 79 4x4, and I got the old t-case. I paid $100 bucks for the 205.
    BIGJ
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Lucky dog [​IMG]
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    Doesn't putting a shorter output shaft in the tranny require disassembly of the tranny? Does it require the tranny to be pulled?
    New 4x4 driver: "A lot of money in that truck, eh?"
    Me: "Oh, about 1/4 of a new one"
  10. BIGJ
    896
    Central Arkansas
    Yes, I had to pull the tranny. I called just about every transmission shop in town trying to find someone that would just replace the shaft and not try and do a complete rebuild. I finally found a place that swapped the output shaft for 75 bucks. I also rented a transmission jack, and for installing the t-case and tranny, I would highly recommend one. It made life ten times easier being able to rotate everything front to back and side to side while it was in the air. It took about three hours to pull everything, and about six or seven to to put it back together.
    BIGJ
