208 verse 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bushmaster, Mar 20, 2004.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    im building a 88 blazer from frame up the injected 388 and new rapter 700r4 is mounted in frame now. i was going to use the 208 trans case but will it hold up? i have 2 205 cases both from a standard tranny . i was going to by a slip yoke adapter and cv drive shaft for the 208 but maybe better to do 205 swap? what do you guys think? thanks
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Depends on the type of wheelin your doing. If you want the 208, I would go with the 241 since it has a lower ratio and you get a SYE kit for it. /forums/images/graemlins/thumb.gif
  3. bushmaster
    Jun 1, 2003
    146
    ct
    mild wheeling, towing,hard street use scaring the ricers with a tire smoking 2nd gear shift
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Sounds like what I do! /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/peace.gif
    The 205 is the ultimate in strength, but the 208 has a much lower low range. What is more important to ya?
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    If you don't mind the land anchor that is the NP208 then go with the NP208. Lower low range, lighter, and probably has fewer miles on it. If you've got the time and money to spare, clock the NP208 up.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Why not do a Doubler if you're doing a badass build up.
