208 vs 241
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLZN4FN, Feb 12, 2003.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    what is the difference between the 208 and 241 Tcase?
    I saw tom woods driveshaft has a slip yoke eliminator
    for the 241. Just thought it would be nice to put the 241
    in place of the 208 and get rid of the slip yoke.
    Thanks for your input,
    Bo
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Gear ratio is the main difference 2.72 instead of 2.62
    The design is fairly similar but not exactly the same.
    So parts are not interchangeable but you can swap one for the other. /forums/images/graemlins/thumb.gif
  3. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    The 241 is an updated 208.
    It has a better oiling setup among other little things.
  4. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    The 241 has an oil pump. I'm pretty sure the 208 just has a slinger.
  5. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    What about the speedo? Someone told me the 241 uses VSS
    and the 208 uses a speedo cable? Also has anyone used the
    slip yoke eliminator on a 241?
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Early model 241s are spedo cable with a VSS on the back of the speedometer.. In 1990 they went to an electric sensor on the x- fer case
