229 chevy distributor Q's
Discussion in 'The Garage' started by R72K5, Aug 15, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    does anyone know what distributors will interchange with the chevy 229 v-6 ones ? i need to replace the one on the 84 with a non ECM one that has vacuum advance, it has the 17084132 one right now
    200 and 229 and 4.3L are the same engines, just like the sBC v-8 engines
    thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    78-80 Chevy 200-229 take the same Distributor from Autozone , 30-1695 . Regardless of Camaro , Malibu , or Monte Carlo . These woudl pre-date computers .
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    maybe..
    It MIGHT be the same distributor body as a small block V8 one!(229 is the same block as a 305 only shorter!)..perhaps you could put the V6 pickup coil in a V8 housing,the 229 distributor cap should fit the same as a V8 one.. :thinking: ..never tried it,but it might just work.. :crazy:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeh i wondered about swapping all that stuff too, hmmm
    the 229 cap would fit a sbc housing and everything,
    but can it be done ?
    as long as intake casting is same thickness and the same oil pump/shaft dimensions, etc, since apparently the crank centerline to deck and block height are all same on 200 and up engines
    and yeah everything ive found out so far points to '78-80 200 or 229
    camaros malibus and B bodies as a non computer HEI donor for this.
    the odds of finding someone parting out one of these is pretty slim, i think ill have as much luck with winning lottery really,. especuially nowadays
    so hum,.
    thanks
  5. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    HAD tons of 78-84 malibu's here..
    The junkyards here WERE full of older malibu's and monte carlos with 229's,but I bet they crushed 99% of them in the past year or so since scrap went up again..(Its 75 bucks a ton now here again!)..I bet there are still at least a few I could get a distributor from...but you might check AutoZone's price,my friend just got an older HEI for his truck for 50 bucks exchanged--I bet they wont even look at the core,I'd just slip a smallblock one in the box for the core charge!. :whistle: :crazy:
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i was thinking about it and i dont think id have to swap to non ECM HEI if i were to swap on non ECM carb, as long as i left knock and MAP and O2 and other sensors plugged in
    engine light would always be on but im 99% the non ECM carb and the ECM HEI willl run fine together, but not vice versa i know, an ECM carb wont run right without an ECM HEI i know
    and besides the car runs damn good now after removing and plugging some smog hoses and such, and putting new waterpump on and new gas in it
    been driving it, and took it to work and such today, i like it, its a quick lil get around car, better than the 88 caprice with the 305 was, for sure,
    i may not even need a carb for it now, all it has now is just a little bog on take off from dead stop when its really hot, sometimes
    and thats it
    maybe i should just clean the carb out and filter it im sure the filter is total crap in it, lol i havent checked it and the car sat for a long time parked i know
    thanks
