23 pound pork shoulder, how to smoke it?
Discussion in 'The Lounge' started by stoney126, Mar 14, 2007.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    So I got a pork shoulder and I have a barrel BBQ. How do I smoke it? Any suggestions on rub or marinade?
  2. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Get some Tony Cachere's Creol Butter injectable marinade (they also make one specifically for pork) and inject as directed. Use some extra marinade to wet the outside and rub down with some Corky's dry-rub BBQ seasoning. Hopefully you can find these things out west.
    You will need to smoke it for quite a while, like 45 min. per pound supposedly. You will have to look that up though. You describe a barrel type grill, does this mean it does not have a seperate fire box from the cooking surface. If not then keep the fire on one side and the meat on the other. The purpose is not the heat of the flame so just keep plenty of wet wood chips, and some dry ones too, to keep adding to the fire.
  3. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
  4. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    Damn, beat me to it:wink1:
  5. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    :haha: I was thinkin' Zig Zags but what the hell!
    Seriously, if the Barrel smoker you are talking about is what I think it is you should have a water pan that goes in there, if not you are going to have to mop the hell out of it as you smoke it or it will dry out. Use the water pan if available with some herbs and maybe beer in it and mop it as well and you should be fine, but I'm thinking for that shoulder you're talking 18 hours or so.
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Mang if I still lived in CA. I would have brought the beer.. how did it turn out? :D
  7. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    HEHE no need to bring any beer I gots plenty to go around :D Didnt do it today. Didnt figure it would take so long. gonna start it tomorrow around 8am give er take. Ill take pics:haha:
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    I drink alot .. (PICS brother!!) :haha:
  9. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Cold smoke or hot smoke? I'm gonna assume hot smoke, I do 6-12 pound pork shoulders for pulled pork all the time. I have a great rub that goes good with a red pepper cider vinegar sauce. I hot smoke at 200* on the BBQ, it usually takes 8-10 hours for a 8 pound roast. And, whenever I smoke pork, I ALWAYS use apple wood to smoke it. I've tried hickory and mesquite, but apple is the best. For that matter, any fruit wood tastes good with pork, I've tries pear, fig and plum as well. But, like I said, apple takes the cake.
    Here's the rub recipe:
    1 Tbsp Paprika
    1 Tbsp firmly packed light brown sugar
    1 1/2 tsp chili powder
    1 1/2 tsp ground cumin
    1 tsp coarsly ground black pepper
    1 tsp Kosher salt
    1/2 tsp cayenne
    Keep in mind, this is for a 5 pound roast, so you'll wanna triple or quadruple that.
    Then theres the hot pepper vinegar sauce (still sized for a 5 pound roast)
    1 1/2 Cups Cider vinegar
    2 Tbsp granulated sugar
    1 tsp Tobasco
    1/2 tsp crushed red pepper flakes
    Kosher salt to taste (I use ~1/4 tsp)
    Fresh ground pepper to tast (about 1/2 tsp for me)
    Coat the roast with the rub, then tie it up
    Put it in the smoker, fat side up, with a good head of apple smoke (smoke it the WHOLE time it's cooking) I put a pan underneath to catch the drippings, which I then add to the sauce. Smoke the roast until it reaches 185* in the center (a LOOOOOOOOONG time at 200*). Then put it on a platter and cover it with foil and let it rest for 20 minutes. In the meantime simmer the sauce for 10 minutes. When 20 minutes is up, pull, chop or shred the roast, throw out any large chunks of fat. After it is thoroughly shredded, moisten it with about 1/3 of the sauce. Then put it on some toasted buns ( I like Mayo on mine) and have some sauce on the side for dippin.
    This is by far one of the best recipes I know, and if you ever ate my cooking, you'd know that means something.:D
  10. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    where can I get applewood? Should Install a thermometer? Also what do mean good head of smoke? Build up the smoke then put in the pork?
  11. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    They sell applewood chips at Big 5, OR, I see you're in napa, right around December 'till now, the local orchards ought to have done thier pruning, I use pruned branches from my apple trees. They are about as thick as my pinkie finger, and I cut them about 1-2" long. I use an oven thermometer in my grill (I use a 22 1/2" Weber Kettle). Getting the temp to stabilize is a little tough. I generally fire up about 1/2 a chimney's worth of coals, but dont let them get to tle light grey ash stage, just get them started, then I spread them on either side of the bottom grate. I close the top and bottom vents (not all the way, or they'll go out) so there is minimal air flow, if you find the temperature dropping, open them up a bit, if it gets above 250* close them a bit. I usually try to keep it 200-225*. When it seems like you need more coals, 'cause the old ones are burned up, usuall every 45 minutes to 1 hour, fire up 8-10 briquettes in the chimney, OUTSIDE of the grill, and when they're ready (with the grey ash coating) add them to the existing piles with metal tongs.
    After the first coals are ready, and right before you put the meat on, drop a handful of apple chunks on each pile of coals, then close the lid and wait until smoke starts coming out of the holes in the lid. I guess it's not really necessary to wait for the smoke, as it starts billowing very shortly after the chunks are added. I always add more chunks before the old ones are done smoking, right about when they start to slow down. It's not too hard to mess up, just keep the smoke going and the temp between 200-300*. I know this contradicts my earlier 200-225 suggestion, but crap, its difficult to keep the heat just right, but TRY to keep it in the low 200's. I make sure I check it every half hour or so. I try and position the oven thermometer inside in such a way that I can use a flashlight through the top vent to read it without opening the lid. After the first three hours or so, you should have a pretty good feel for what you need to do to stabilize the temp, by adding coals and adjusting the vents. Good Luck! Ah, and since you're in the Bay Area, I suggest using some GOOD sourdough buns for the bread. The little sourdough rounds, 3-4" diameter from Boudin are the BEST!
    Also, I take the bone out of the roast, if there is one. Then apply the rub, and roll and tie it up into a nice "roast" looking chunk of meat.
  12. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Yeah, I grew up with Zig Zag too :D :bow: !!
  13. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    :waytogo: :waytogo: :waytogo: :whistle:
  14. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    We didnt use the whole shoulder, we only used half. This is about 3 hours in. Also pic of my dog in a hole and me and the ol lady
  15. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    I thought only people in NC used a vinegar sauce, guess someone else has good taste :D. this recipe is similar to what I use for pork BBQ, minus the tabasco, I add it later to my own plate.
  16. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Lookin' good!
    nc87K5, the book I got this recipe out of touted it as an Eastern Carolina thing, I definitely prefer it over tomato based sauce, which they claim is a western Carolina thing. When I first decide to try the recipe, I thought it sounded funky, but he pic in the book said a thousand words, and it is one of my all-time faves.
  17. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    yea, I've tried that red sauce (Lexington style) and it sucks on pork. vinegar on pork is better.
    oh yea, add a lemon to that also, makes it even better IMO.
  18. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    That was some really good pork. Some of it still smoking. Made the vinegar sauce and it was very very good. My wife and sister put bbq sauce on it:doah:
    I tried a lil bbq on some and it ruins it to be honest. All you taste is bbq sauce. The vinegar works well with the pork. But I munched a bunch just plain by itself too:haha: Thanks for the tips and info guys, gonna do the other half saturday
  19. UseYourBlinker
    Jun 7, 2000
    11,117
    Look's good. I might go get me a pulled pork samich tomorrow. :D
  20. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Hahaha..... "pulled pork"
