24 volt starter...
Discussion in '1982-Present GM Diesel' started by HD, Mar 15, 2004.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    My starter went out about 2 weeks ago and I went to a junk yard and got a starter off of a military Blazer. It cranks really slow, even though I have 2000 CCA form my batters. So today I thought about the starter coming out of a military Blazer and thought that it was a 24 volt starter. So my question is; is there a way to change it to a 12 volt starter, maybe by changing the solenoid?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    /forums/images/graemlins/thinking.gif
    Nope
    If you were the adventurous guy, and knew enough in electric components, you could go in and reconnect the windings to work with the 12v. But it's not as simple as just the solenoid.
    /forums/images/graemlins/whistling.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    having same exact problem with an oldsmobile 350 engine, it cranks reaaaaaaaaal slow, with both batteries all way charged up, if it doesnt start up soon then it will probably go into shredder :/
    dunno
    good luck
  4. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    You could connect your 2 batteries with a switch for starting to get 24v. It's not that hard.
