24 volt winch to 12 volt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Jan 31, 2002.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Has anyone here wired a 24 volt warn winch for 12 volt use. I do have dual batteries but not set up for a 24 volt system. Is there a benifit to running at 24 volts? Thanks for any info.
    Mike
    The jeep eater ......[​IMG]
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes there is a benifit to running 24V over 12V.
    Half the current to run the winch, meaning twice the run time !
    Smaller wires to the winch.
    You will need to wire the batteries, winch, and alternator very carfully.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can't wire a 24 volt winch to run on 12 volts. It requires changing the motor to a 12 volt version. [​IMG] Your alternative is to figure out how to use your existing batteries in series, to supply 24 volts to the existing motor. It shouldn't be too hard to supply 24 volts to the winch and still have just 12 volts to the rest of the truck.
