241-208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazerboy16, Mar 26, 2000.
  1. blazerboy16
    blazerboy16 Registered Member
    Mar 14, 2000
    10
    Vermont
    looking to swap my 241 with a 208 on my 89 k-5 with TH700 trany will it work?
  2. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    YES it will. I just did it a month ago on my 89. Just make sure you have the 208 shift linkage because the 241 linkage will NOT quite cut it. Other than that, it is an open and shut case. My brother and I had it done in an afternoon using no special tools and floor jacks, (not the best way). Just undo the four bolts that connect the t-case to the tranny, slide one out and slide the other in and bolt it in. Good luck...keep me posted on how it goes!!
    10 BOLTS O' FUN
  3. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I most be all screwed up because I thought that 89's had 241np in them. What year did they put the 241 in then. I know they came out with the 241 in trucks starting in 88. Please let me know. Thanks
    Donovan
  4. blazerboy16
    Mar 14, 2000
    10
    Vermont
    I dont think i have the 208 shifting linkage but i do have a torch a welder all the steel you could ever want and a A+ in welding class. Think i can do it?
  5. Crash90K5
    Crash90K5 Registered Member
    84
    Santa Clara, CA.
    Why?? The 241 is stronger than the 208, if you want to consider an aluminum case and chain drive strong... They both have the slip yoke in the case, both got chains, why not get a 205 or Atlas?
    [​IMG] <font color=blue>Crash90K5</font color=blue> [​IMG]
  6. blazerboy16
    Mar 14, 2000
    10
    Vermont
    Im changing to a 208 cuz i cracked my 241 and have a 208 kicking around. Is the 208 geared lower?
  7. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Just for the record, my 88 has a 208 in it. And I'm pretty sure the 208 is the lowest geard stock production t-case.
    Corey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  8. Crash90K5
    84
    Santa Clara, CA.
    I know the NP241 (that's what came in my 90) has a 2.6:1 ratio. I think the 208 is the same?
    Joe, sorry, didn't know the situation. By all means, go the cheaper (FREE!) route and throw in the 208...
  9. Donovan
    524
    Arvada, CO
    Maybe I should learn to read alittle closer. I thought that you was going from a 208 to a 241. Sorry about that. By the way what do you want for that cracked 241 t/c?
    Donovan
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The 208 has a 2.61 ratio. The 241 has a 2.72 ratio. The 241 was first used in 1988. The 208 was first used in 1981.
    ken
