241 adapter question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dave_90_blazer, Dec 26, 2005.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    is the adapter for a passenger side drop and drivers side drop the same ?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I can't see why they wouldn't be unless GM decided to make the bolt pattern different between the two just so you couldn't do a swap easily. Actually that is the only difference i could see there being and i doubt that GM would do such a stupid thing but then again i've been wrong before about that one. Maybe someone else with a little more knowledge about the driver drop will chime and and give you a definate answer.
