241 Cracks
Discussion in 'The Garage' started by fwc, Jun 7, 2004.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    As a result of a u-joint/slip yoke failure my rear driveshaft smacked the back of the transfer pretty good. The "pump retainer housing" ended up with a crack around one of the bolt holes. Does anybody know where to get a replacment? Is it possible to weld the piece back on? Any suggestions? For what its worth, my 91 Jimmy is essentially stock and is a daily driver. Thanks in advance /forums/images/graemlins/thumb.gif
  2. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    junkyard usually got the piece, but talking them out of taking apart a good tc in the problem. You can get a machine shop to weld it up also, had it done plenty of times, as long as you have most of the pieces so they can weld it together, especially around a bolt hole, or just have em weld a solid piece on and drill you a new hole. Probably cost you 60 bucks to get it done that way.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd get it welded up at a good shop. Make sure they clean it real well and it should be sucessful.
  4. fwc
    Nov 2, 2003
    84
    Northern Virginia
    Thanks for the tips so far, welding seems to be the way to go. There really arent too many donor trucks to be found in boneyards around here anyway.
