241 from 91 into an 89
Discussion in 'The Garage' started by MTBLAZER89, Jan 22, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    What are my options here with the speedo? I might be buying a 91 case with a SYE. Is there something simple to swap to change the 91 to a mechanical speedo output? Can I just swap in a 90-91 gauge? What other problems am I going to run into with this?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I too, would like to know more :)
  3. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    I AM CURRENTLY GOING THROUGH SOME SIMILAR ISSUES. THERES A COMPANY IN CALIFORNIA THAT HAS A LOT OF SOLUTIONS FOR ISSUES WITH THE SPEEDO. THEY'RE CALLED STEALTH CONVERSIONS AND THE WEBSITE IS WWW.JTRPUBLISHING.COM. THEY WERE PRETTY HELPFUL ON THE PHONE FOR ME, THE PHONE NUMBER IS (925)462-3619
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    use the 91 t-case, get the 90/91 cluster w/connector, and the 90/91 drac w/connector, you may need to do a little soldering on the drac to calibrate it, but i can help you there, i did it to my 90
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You have a 89' so what is wrong with the 241 you have now?
    If you really want to run the 91' t-case just swap the tail section from your 89' onto the 91'.
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Well I was just looking for ease of install, but it looks like he is going to keep his case now anyway so I'll just be buying a new SYE. Thnaks for the help anyways.:D
