241 IFS vs. straight axle
Discussion in 'The Garage' started by smalltowncowboy, Aug 29, 2006.
  1. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    i have a chance to pick up a 4500/241 for really cheap but its in a IFS truck. from what ive read the IFS 241 is a driver side drop and the truck im would be putting it in is a passenger side drop. am i SOL or is there a way around this problem?
    any help would be thankful
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could get a different side drop transfer case or you could change to a axle with the diff on the correct side
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a Ford Dana 44 or a Dana 60 from a 78 or 79 F250 or F350 would be pretty much a bolt in deal. both are hi pinion axles to boot.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you'll also run into problems with speedometer drive, since your truck has a mechanical speedo, and the IFS truck has an electronic. should be able to swap on an 88-89 241 behind it and retain your mechanical speedo without much problem i would think.
  5. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    :waytogo:
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if u can get a 4500 for cheap....GET IT!
  7. smalltowncowboy
    Jan 16, 2006
    503
    hermiston oregon
    i can get the 4500/241 and all components (slave cylinder, master cylinder, blah blah blah) for 250 bucks. well buying the whole truck for 650 but i have the rest sold already for 400. what i wanted was a cheap upgrade, im trying to buy a house right now so i cant see buying the tranny/tcase, and then a new axle, new wheels, possible new tires. its just not what i can do right now.
    my ultimate plans are unimogs for axles, then i will need the driverside drop. but who knows how long it will be till i can get the axles.
  8. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    what spline is the input is the 241... if its teh same as your current tcase, simply bolt up your current case to the 4500 and call it good
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    wow a nv4500 for $250......thats basically giving it away
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you weren't so far away and I so rarely get up to Powell Butte I'd be interested in that driver side drop 241.
  11. smalltowncowboy
    Jan 16, 2006
    503
    hermiston oregon
    im not sure what the spline counts are for either the 241 or my 208. the 208 is bolted to a th400 and theyre from an 87 1500 p/u.
    right now im in idaho and dont have the ability to do much checking.
