241 questions
Discussion in 'The Garage' started by mudman83, Apr 25, 2005.
  1. mudman83
    mudman83 1/2 ton status Premium Member
    Feb 11, 2004
    141
    Mesa, AZ
    I am rebuilding my 241 transfer case and have seen many posts that say to change the chain when you rebuild your case. Is there a way to tell if it is worn because it looks ok and how far can you clock a transfer case before it starts hitting the floor of a stock balzer with no lift? The gear that drives the rear out put shaft and slides in and out of low and high range in the planetary is also showing wear on its teeth, is it ok if i left it or should i get a new one or is it possible to get a new one?
    Thanks for the help,
    Kyle
  2. mudman83
    Feb 11, 2004
    141
    Mesa, AZ
    Can anyone answer how far you can clock a tcase before it hits the floor on a stock blazer and no body lift, or how to tell if a t case chain is worn?
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    When I rebuilt my 241, I had not a mark on my chain, but I'm convinced it was the cause of the failed range fork....I would say chain replacement is as crucial to a rebuild as bearing/seal kit... I got my parts from www.nationaldrivetrain.com (ship from Chi and Atl), and exploded view from www.motivegear.com (wholesale only) Total for bearing/seal, range fork, chain ran about $250 plus shipping...worth every nickel
    Haven't a clue about clocking a TC
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    two hundred and forty one questions! Holy cow, that's alot of questions! Ohh...you mean the transfer case...silly me....
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    HAHA
    If the chain is burned and hard to roll, id replace it, otherwise, its prolly fine. Id put new inserts on the fork too.
