241 rebuild kit, I need one
Discussion in 'The Garage' started by desertrat67, Oct 6, 2006.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Where can i get a rebuild kit for a 241? i pulled my t-case to install the sye this morning, got it torn apart and found the nylonpads that go on the shift fork ends are gone on both shift forks and the material has travelled all over the case. The pump is missing two of the four ears on it, nd I have a crack in the rear half of the case housing. The crack i don't think I am too worried about, since it is on the top of the case and I am pretty sure the rear half doesn't have that much force applied to it during use. I'll take that in have the ends drilled so the crack doesn't sspread and have a shop weld the crack if it is possible. The forks need to be replaced along with new nylon pads installed. Thanks, ryan
  2. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    www.nationaldrivetrain.com is where I got my stuff. Bearing and seal kit was about $110, chain $80, pump $55, range fork $55. The teflon pads come in the kit. I cheaped out and didn't replace the chain the first time, so I did it twice. My chain was shot and didn't have a blemish on it. Several folks on here have found a bad to moderately worn range fork once they get into it. You can't see it until you take it out. Mine was the one that had the numbers stamped on it (you'll see from the catalog)
    They ship from Chicago and Atlanta as I remember. It's been a year or so since I did mine.
  3. MagnuM4WD
    MagnuM4WD 1/2 ton status
    Jul 26, 2006
    138
    Bucureşti - România
  4. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    thanks guys. I think i like this better than my thought to buy another used case and possibly have the same problems with it.
  5. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    I have been debating doing the slip yolk elimiator myself, how hard was it for you? I just rebuild my 241 so I don't need to worry about that. Thanks for the heads up!
    ~Brian
