241 spline?
Discussion in 'The Garage' started by shaun, Dec 1, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Is the only difference between a 27 spline 241 and a 32 spline 241 the mainshaft? So can I just replace the 27 spline shaft in my 241 w/ a 32 spline so I can mate it to a t400? Anyone done this or know if it will work?
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I THINK the main shaft is the only difference but I definantly don't know for sure.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have talked to the guy's at JB Conversions and an engineer at NVG and they both stated that the input gear on the 2.72 planetarys will interchange - so it looks good for your swap /forums/images/graemlins/thumb.gif
    Tom
  4. shaun
    Apr 22, 2003
    745
    So to make sure I understand all I need is the mainshaft and just rebuild my tcase with the 32 spline shaft. The input gear was the other part I was wondering if I needed to change. Thank you for your time. Now I just need the adapter and then a tranny. /forums/images/graemlins/peace.gif
  5. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    The mainshaft ( or out put shaft of the transfer case ) will not effect the change of the input gear on the 241 .
    Or are you talking about the rear output shaft of the tranny ?
    If so than you would need the input gear for the 241 that is 32 spline and the adapter along with matching tranny output shaft .
    Does this help ??? Tom
  6. shaun
    Apr 22, 2003
    745
    Is it the input gear that I have to change to 32 spline to mate my 241 behind a 400
  7. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Yes ! /forums/images/graemlins/thumb.gif
  8. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    Yes the 32 spline shaft will swap right into your 27 spline case. I did the swap pb a year ago when I swapped a 4l80e into my blazer. Good luck
    Remington
  9. shaun
    Apr 22, 2003
    745
    So you just changed the input gear
  10. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    All you need is the 32 spline input gear. It will swap right in place of the 27 spline. I did it on mine.
  11. shaun
    Apr 22, 2003
    745
    thanks
