241 swap questions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4man, Sep 12, 2001.
  1. 4x4man
    4x4man Registered Member
    Dec 5, 2000
    10
    bainbridge georgia
    im converting my 95 Z71 to solid axle. i want to use a chevy dana 44. my 241 tcase has the output on the wrong side. i have a ford dana 44,,but i want to use the chevy one. my 241 has the tcase shifter on the drivers side and it has a electronic speedometer. does the 241s off the early 90s blazers and subs that have a solid axle have the electronic speedometer and left hand shifter for the tcase?
    oooooopsss,,,,,,was that your lowrider i just ran over.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    why not go with a dana 60 from a f*rd. i think they are more common to find.
    my 2 centavos.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  3. 4x4man
    Dec 5, 2000
    10
    bainbridge georgia
    naw,,i have a c clip 6lug 14 bolt rear. but i do need to find out the info on the 241
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I *think* that the later models have an electronic speedo. 90-91. I know my 89 doesn't though. You might look at the specifiactions link at the top and see if Steve listed it in the different model years.
    The shift on my 241 comes straight up through the middle of the floorboard. My suggestion would be to just find one and look at how the linkage is.
    Good luck
    Kyle
    89K5
  5. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    My '91 SM465 - 241 has the electronic speedometer and the shifter is on the right (passenger) side of the case.
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    My 90 241 has the shifter linkage on the passenger side as well. If I were you, I'd just use the Ford axle or sell the whole truck and get something older.[​IMG]
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
