241 SYE Install ?????
Discussion in 'The Garage' started by wayne, May 20, 2003.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Got my SYE from Jess today and have a couple questions since it has no instructions.
    1. Does anybody have pics of the install or the kit installed?
    2. Where does the round metal shim go?
    3. Does anybody know torque specks on the bolts for the flange and yoke?
    4. Anything else I need to know?
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    It's been a while since I installed mine but I will try to help.
    1. No pictures taken during the install, but here is one of the installed product. This is a pic of mine I sent to High Angle Driveline and he is using it on his site.
    2.This is from the instruction sheet I received with the kit. "Place the thin, flat, thrust plate(supplied in the kit) onto the shaft and lower it down onto the top of the drive sprocket. Using snap ring pliers, install the snap ring just above the thrust plate..."
    3. Yoke nut torque specs: "90-130 ft lbs."
    4. Yes the oil pump pick up tube is a pia. Make sure you get that back togther correctly when putting to case halfs back together.
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Would you by chance be able to scan the instructions and upload them? I'm a little lost on the shim but have an idea on where it goes.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    These instructions came with the kit from H.A.D. The instructions are for a 231, so they are not exactly the same as the 241.
    I can scan them, but it may take a day. Do you have access to a fax? Or I can snail mail a copy to you.
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No access to a fax. I am planning to do this in the next day or so. If you can scan them that would be great. Thanks a ton for the help. /forums/images/graemlins/thumb.gif
  6. DUKSRULE
    DUKSRULE 1/2 ton status
    Nov 25, 2001
    303
    Va Beach Va
    I am not trying to High Jack this thread but can someone with the 241 SYE installed tell me what the length of the finished cas is from the transmission mating surface to the driveshaft flange mating surface? Also how much is the kit and where can I pick on up?
  7. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I got my kit from Jess at Highangle. Total cost shipped with flange for 1 ton CV driveshaft was $470. As far as the length goes I will post it as soon as it is together.
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Sent you a pm with the information. Let me know how it works out.
    Later,
    dp
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Later,
    dp
    Links work but I can't view. I responded to your PM. Thanks a ton for the help.
  10. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Sent you 4 emails with the pics. Let me know if that works.
    No problem on the help. That's what this board is for...
  11. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Got it. Thanks Again. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
