241 Tcase options
Discussion in 'The Garage' started by highrlr, Feb 23, 2005.
  1. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    I have a 241 tcase in my '89 Jimmy and I was wondering if there are any sort of lower gearing options for it other than say a klune v or other reduction unit. Since it is chan drive I am guessing there are not many options for it. Is there a better tcase that came factory that I could swap into my truck without alot of expense or hassle that would be stronger and have more lower gearing options? Also if i do endup keeping my case I am going to rebuild it and do a SYE, who has the best prices on a rebuild kit and SYE? And if I remember correctly you can choose what size yoke you want or if you want a flange with the SYE, is it more personal preferance or is one stronger than another?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I don't think there are lower gears for it. It is the lowest geared (factory) GM case. The 205 is the strongest, but the 241 is a good case. Downsides of it is the slip yoke and the aluminum case. JB conversions makes a Std short SYE kit for $199 right now (link on CK5 main page). Put a good skid plate under it, and you have a pretty reliable setup.
    Oh yeah I believe you can get a bigger yoke...not sure on the flange. The yoke just requires a little milling IIRC.
  3. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    $199 sounds pretty reasonable, Ithought they were in the $300 range. How are these things to rebuild? Are there any special tools needed to do it or can i do it in my garage with standard tools? Oh and are there any manuals or write ups out there on it?
  4. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Oh and where can i find a clocking ring for they 241? It has the same pattern as a 208 so a ring for that should work right?
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  6. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The clocking ring above should work, or I bellieve DP_90K5 sells them as well. I think they are pretty strait forward to rebuild.
  8. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    [stupid newb question] Did the 241 come in a drivers drop? [/stupid newb question]
  9. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Yes, in IFS trucks.
