241 to 208 swap?
Discussion in 'The Garage' started by ftcjimmy, Jun 20, 2005.
  1. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    ok.. so the housing cracked on my transfers case (rear output shaft housing) so after much searching for the part i gave in and bought a new transfer case. i thought i had a 208..being a newby i didnt know.. so i found a replacement 208...get home, look into it a little bit, realize i had a 241. is the 208 im utting in stronger or in anyway better then my 241? if not let me know so i dont make a mistake. thanks, dj.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 208 is technically marginally weaker then the 241. It is not enough to worry about though. It is a direct bolt up replacement for a 241 though as long as the input spline count is the same.
    208/241's from behind 700R4's have 27 splines on the input.
    208/241's from behind SM465 (manuals) and TH400's have 32 splines on the input.
    Harley
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    [hijack]
    Was there ever such a thing as a LH drop TH400 or manual app. 241?
    [/hijack]
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    The other difference is the the low range gearing. The 208 has 2.62:1 ratio & the 241 has 2.72:1. I could be wrong on exact #'s, but am close enough. You probably won't notice a difference between the two.
    Also, what year rig is yours? In 90, the 241 was electronic speedo whereas the 89 versions were mechanical.
  5. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    ftcjimmy,
    if you're that concerned with strength, you should look into a 205. they're pretty much bomb proof -- not only is the case stronger as it's cast-iron vs. aluminum. the internals are gear-to-gear not chain driven. i have a 205 if you're interested in one. im in philadelphia, pa
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    You interested in selling your broken 241?
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    depends on if you want crawl ratio or strenght..
    205 is strong but I hear the 208 is geared lower...
    I have a guy coming to get my 465/np205 already mated together
    then I got a jimmy im buying.. maybe selling the 465/np208 already mated.... :grin:
