241 Transfer case question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79ChevySB, Feb 11, 2002.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    How do you guys sift your 241 into low range? The manual says that you need to be moving at about 5mph with the tranny in neutral, and just "swiftly" move it into 4-low. It even says something like dont slow down around neutral, just keep going. Well when I do it like the book says, I'll get a metal clang noise coming out of it. Is this normal? Its not that loud, but something that made me wonder.
    AAAhhhh Christ a IFS Blazer, jeez its stock too, does it get any worse??? Could be a ford.
  2. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    I am at a complete stop when I shift mine. If I am moving it makes horrible noises.
    Kent
    1989 K5
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm usually stopped too.
    90K5
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I will try to shift it SWIFTLY in neutral at a complete stop at first but if you are locked with low tire pressure sometimes it helps to be rolling VERY slow. Everything gets bound up I guess....
    And swiftly doesn't mean forcefully. If it binds, bump it forward or reverse first and then stop and try in Neutral again. I use the rolling method as a LAST resort. And don't force it - you will learn the way your truck likes and it should be a silent and smooth shift.
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  5. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    When you guys are at a complete stop, Im guessing that your tranny is in neutral. If Im wrong let me know, but thanks for the info.
  6. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    My 241 prefers to be stopped and in neutral.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yes, neutral. Also on flat ground is easier but when you need 4 low that can be hard to come by.
    Dave
