241 Transfer case speedo
Discussion in 'The Garage' started by JUNIOR-K5, Jan 18, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Is it possible to convert a electric speedo to manual on a 241 if so what is needed:confused:
  2. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I think you have to change the whole back half of the case. But I'm not for sure. Try a search. This is one of the things I've got on my long term mods list.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    1989 is the only year of mechanical speedo for a 241, go find yourself a 1989 241 and swap over the required pieces.
  4. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    So basically to make it mechanical all I need to do is take off the back half.Also would it be possible to use parts from a 208 I have one sitting in my yard.
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No the 208 stuff will not work. You will need the speedo housing and the gear for the shaft. The shaft is the same from the electronic to the mechanical.
  6. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    So basically all I need is the housing and the blue gear for the speedo right everthing else is the same.
  7. dyeager535
    26,979
    Don't know what the end application/desire is, but is swapping over to electronic speedometer an option?
    Not sure which one is a better option for you work-wise, but the electronic speedo is nicer to run for sure.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yep. The hard part is going to be finding somebody willing to split the pieces out of the case. Are you planning to replace a 208 with a 241?
