241 vs. 208.....who wins?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban350, Aug 22, 2002.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Whats stronger, 241 or 208? Thanks /forums/images/icons/laugh.gif
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    IMO, I would say that they are both pretty equal.
  3. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    241 is stronger because it uses 6 planets in the planetary unit and the 208 uses 4 planets.
  4. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Easy 241
    2.72:1 low range (208 is 2.61:1); as in post above, 241 has a stronger 6 pinion carrier (208 has 4 pinion carrier) and 241 is supposed to have better oiling system.
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    241's you can also buy a SYE kit but not for the 208.
  6. BigBurban350
    Jun 9, 2002
    711
    Michigan
    whats the SYE kit?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Slip
    Yoke
    Eliminator
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    Is the 241 a direct bolt-in to a 700 that came mated to a 208?
  9. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    241 Wins!...Better oiling system,able to get a fixed rear yoke and you can install 4:1 lo-range gears!!Mike
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Yes, a 241 will bolt directly in where a 208 was.
  11. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Some guy's have made there own SYE kit for the 208. /forums/images/icons/tongue.gif
  12. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Who makes 4 to 1 gears for a 241? I NEED TO KNOW THIS /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  13. jimmy88
    Feb 17, 2002
    351
    Detroit, MI area
    Just make sure you get the 241 with the same speedo drive as your 208. Some 241's come with mechanical cable drives and others come with electric sending units.
