241 wont stop leaking?
Discussion in 'The Garage' started by shaun, Apr 13, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    How do you pull the breather tube out of a 241. I beleive that is were it is leaking. I had a pretty bad leak so I pullec the case and replaced all the seals. But I am still getting quite a bit of tranny fluid in my skid plate and it looks like it is coming from around the vent tube. /forums/images/graemlins/dunno.gif
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Maybe the seal between the tranny and T-case is bad...which would cause the 241 to become overfull regularly. Have you checked the tranny fluid level?
    Rene
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Did you reinstall the hose on the breater tube?
    I had the same problem when i did my trans swap, didn't reinstall the hose and kept spraying fluid all over, put the hose back on and no problems since. /forums/images/graemlins/thumb.gif
  4. shaun
    Apr 22, 2003
    745
    I replaced that seal as well as the one between the t case and adapter. But I will check My tranny fluid at lunch. It isnt coming out of the breather tube itself. But from all around it. The whole it plugs into.
  5. shaun
    Apr 22, 2003
    745
    anyone else /forums/images/graemlins/dunno.gif
