241c 4to1
Discussion in 'The Garage' started by chevystepside, Dec 24, 2002.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    man there has to be a cheaper way of doing a 4to1 tcase without paying 1300.00 i want to stay with the 241c is there any way to piece it together by means of junk yard stuff. or with out having to replace th front half of the case
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I dont think that 4to1 has what it takes for a Blazer. They are using them in things half the weight.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    There is no way to piece it togeather. You will have to buy a kit. The nice thing is you can use your existing driveshafts and SYE kit if you have it.
    Butch, as far as it holding up there are a couple of us here looking in to it. I want to run the 4 to 1 in Donna's K5. The 241 will deffinately hold up well in stock form so if it is a quality kit it may do well. I understand where you are comming from since the 231 kit is used in Jeeps and lighter weight vehicles. It would be nice to have other options other then the Doubler or other t cases.
  4. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    If you'll cal Lisa at my shop after Xmas she'll get you a much better price than that.
  5. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    Yeah I think the planetary would make it, but I see bad things happening to the chain. /forums/images/graemlins/grin.gif
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I know the 2.72 planetary is really strong, I'd suspect the 4:1 planetary. I'm not sure what gear it is but if it's like the 231 gears I wouldn't let a truck near it. They have to be timed and can end up only loading a couple of teeth which is why they sometimes come apart in jeeps.....
