241c rebuild?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bvrbtr, Aug 29, 2006.
  1. bvrbtr
    bvrbtr Registered Member
    Aug 28, 2006
    17
    Oakland, Ca.
    I'm just wondering if any of you guys would be able to tell me how hard is it to rebuild a 241c transfer case, specificly the oil pump inside the t-case?
    thanks to anyone who can help me
  2. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    are you wanting to put an new oil pump in or are you wanting to rebuild the whole thing? the oil pump is in the back cover piece and it is operated by the rear output. it is not buried by the gears or the chain and it is one of the last things to be put on upon rebuild. hope this helps.
  3. bvrbtr
    Aug 28, 2006
    17
    Oakland, Ca.
    No, just need to replace the pump so far, thanks for the help.
  4. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    Go to JB Conversions website. They have some good photos and explanations for installing a SYE. The pump is specifically shown in one of the shots.
  5. bvrbtr
    Aug 28, 2006
    17
    Oakland, Ca.
    Okay now I feel like a newbie whats an SYE? and do you have JB Conversions website address?
  6. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    SYE = slip yoke eliminator, like it says, it eliminates the slip yoke design and replaces it with a fixed yoke on the transfer case output. You then must get a new driveshaft that has a slip shaft on it. The 241 SYE allows you to run a slightly longer shaft, thus decreasing driveline angle. Plus, if you ever grenade that rear shaft, you can remove it and drive still drive the truck in front wheel drive. If you tried that with a slip yoke 241, you would lose all the TC fluid.
    http://www.jbconversions.com/
    Replacing a 241 pump is pretty easy. You just need to split the cases, remove the old one and install the new one. If your TC has some mileage on it, I would consider changing the chain while you have it open. How do you know the pump is bad?
