24v Cummins gear ratios
Discussion in 'Tow & Trailer' started by DEMON44, Jun 23, 2006.
  1. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    OK So I've finally stuck the 35's on my '98, currently 3.55s and 35's suck even with cummins and nv4500.
    So question lays is who has 4.10s with similar setup? 2nd gen cummins 4500 35's? I'll likely go to 37's when the 35's are fried.
    How is the towing?
    Thanks.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I have heard that the 4.10 trucks really like 35's, so I would assume that a swap to 4.10's would work well for you, especially with plans of 37's.
  3. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    :thumb: Thanks. I'd tinkered with those RPM calculators and the #'s looked good, I wanted a second oppinion.
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I have 37 and 4.10s (factory gears) It isn't too bad but i did notice the difference after putting on the tires. flys on the freeway now! my truck is pretty heavy (dually/crewcab) so you may be even better off (if your lighter) . I have had thoughts of lower gears and and ARB up front if they even make one but I need to pay for this truck loan first.
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I'm in a '98 quad cab shortbox 2500 stock engine power.
