24v starter
Discussion in '1982-Present GM Diesel' started by shaun, Jun 2, 2005.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Is there a difference between the 24v starter on the cucv's and the standard 12v starter for a 6.2. This is all on my 86 k3500. The starter got stuck yesterday when I was trying to start it. I pulled the key and it kept trying. So we pulled the neg battery cable. Apparently the inside of the starter got stuck and kept trying to crank. Can I use the 12v starter or will it not work?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I would pull off the starter then open up the solenoid first. you probably just need to clean the contacts inside the solenoid or rotate the battery post terminal in the solenoid.
  3. shaun
    Apr 22, 2003
    745
    How do you do that.
