25 or 31 gallon gas tank?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pomai, May 24, 2006.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    I need to know what size gas tank do I have. I've never been able to fill it over 25 gallons, but all listing even GM say for my 1988 Blazer I have a 31 gallon.
    Thanks, Ed
  2. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Does it have a skid plate under the gas tank?
    If so a 31gal tank would be real close to it. If it's a 25gal take, you'd have about a 1" gap like mine does.
    Even if I run it down past "E" I don't end up putting in more than 20-21gal.
  3. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Yes is has a skid plate under the gas tank. LMC truck does not list a 88 with a 25 gallon tank and neither does GM.
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i asked one time on hear in the garage. thay basicly told me if the 2 halfs of the tank are same higth then 25 gal. if bottom is taller than top half then 31 gal tank.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    To put it this way, i've seen alot of blazers over the years and i've only seen one 25 gallon tank. This would lead me to believe that you probably have a 31 gallon tank, but now that i've said this you'll end up with a 25 gallon tank. :rotfl:
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    who knows, maybe someone stuck it on there along the line.
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    you can run completely out of gas and still have a few gallons in the tank.the pickup is an inch or so off the bottom of the tank. i never get more than 28 gallons in mine, and thats with driving til the engine stalls.
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    my 88 k5 has a 25gal tank, its annoying, im lookin into a 40gal tank eventually along with diesel swap
