2500 hd rear end
Discussion in 'The Garage' started by 69K5, Dec 2, 2005.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I found a rear end out of a 2003 chevy 2500 hd diesel at the u pull it. they want 170 for it. should i get it for my 69 blazer? anybody know spring perch widths, ratios, rim difference?, ect ect . its an 8 lug version. My front ends are 3.73 and 4.56 so i hope its one of those.
    thanks for the suggestions
    69k5
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    they also had a 14ff in a truck and something else in a crew cab. both for $70. it was a dod truck and had massive drums on it. maybe 14 inch drums. it said 3+3 on the side but it didnt look like a dually rear to me. i wanted to say d70 but i could not find any numbers on it that said D anything. how do I know what it is?
    oh yeah drum turns over 1 complete time to 2 full turns of the yolk. I forgot how to get the ratio from that.
    and I hate to ask but would any ford 8 lug rear ends work? they had tons of those.
    thanks
    69k5
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    the truck had the allison automatic in it if that makes any difference.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    That newer axle is an 11.5" axle. Same shafts as a 14 bolt in thickness. Locker selection is nill, there's a few people that actually make gears for it. I'd stay away...too new and the aftermarket just doesn't make stuff for it.
    I'd just get a 14FF or the D70.
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If it was a gas motor, then they only come in 4.10. If it was a diesel they came in 3.73, 410, and I think 4.56. Ive seen a locker for the 11.5 axle, but it was expensive. Like the 89gmc said, I would go with an older 10.5
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if it is out of a diesel it will only be a 3.73 rear end....
    thats a HUGE rear end that you will never need the beef and extra weight of. a 14 bold will cost less, have the right spring perches and width. the new axle would be nice with the HUGE brakes but the 14 bolt is easily updated to disks.
    Grant
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I already have a disc brake set up for my old eaton. I can just swap it over. I can find more stuff I neeed i'm sure to spend the extra money on.
    I didnt realize it was an 11.5.
    thanks
    nathan
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    daYM grab that allison
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    this truck ran head on into an 18 wheeler the allison snapped in 2. the slip joint on the d shaft broke and thats why the rear survived.
  10. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    88-up new body is 47" spred on perches center to center pin.
  11. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    sweetk30
    thanks for the measurement. I didntr get to go today. I'm still undecided about getting it or the other one.
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Id snatch that axle up, definetly worth more then 170.
