260H comp cam question.
Discussion in 'The Garage' started by mr_clean, Mar 18, 2005.
  1. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    Will new stock vortec valvesprings work with a 260H Comp cam?
    Everything I've read so far seems to say they will be fine, but I thought I'd run it by you all here first.
    Thanks,
    Scott
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    looks like the votecs can handle ~.460 lift and the cam is .440 lift. id make sure to run 1.5 ratio rockers and youd be fine.
    now that i think about it, isn't the vortec a roller motor? if so the valve springs would be too weak.
    a new set of Z28 springs are cheap and good to .500 lift, i run these springs with a comp XE262H
  3. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Yeah, the weakness of the springs is what I was concerned with. I don't want to start floating valves the first time I rev up past 4k
  4. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Is this a roller cam? Need more info on what you have already and what your installing to say what works.....
    George
  5. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Sorry, no it is a flat tappet cam,
    260 adv dur,
    212 @ .050
    440 lift
    110 lobe seperation
    the heads will be new stock assembled vortec heads.
    engine is being rebuild .020 over w/flat top pistons.
    I'm not sure what other info you might need...
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I think the heads as is wi9ll be fine.... If you want, compare the ratings that Comp and the General put out for both....
