27 spline input
Discussion in 'OffRoad Design' started by CaSub, Mar 30, 2006.
  1. CaSub
    CaSub Newbie
    Jan 30, 2006
    modesto
    I just picked up a 203,doubler,205. 203 has a 27 spline input. 1 st, what output from a th350 can I use/need? Any stock app or is there a aftermarket avail??? 2nd the 205 has a small yoke any suggestions on a larger one?, 3rd it has the ORD twin stick, 203/205, is the ORD 3rd add on the right one for a front/rear addition or do I need the whole new triple stick, thx....Jeff
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    #1 = the 3/4 stick out input from any th350 that had 203 /or 205 on it.
    #2 = easy to fix. just order the yoke size you want. if its for the rear yoke. if the front then need to pop off and count the splines to get correct part. if 10 spline now is the time to upgrade to 30 or 32 ford shaft.
    #3 = yes there is a kit.
    just call for the parts as thay are so bissy thay havent had time to respond to the site these past few weeks. hope this helped you. good luck.
  3. CaSub
    CaSub Newbie
    Jan 30, 2006
    modesto
    Thx for the info, its got the 32 spline. time to spend more$$$$$
