285/75/16 good enough for stock suspension K20????
Discussion in 'The Garage' started by 1985K20, Mar 20, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Thinkin about buyin a set of Mud T'S BF'S: 285/75/16...That good enough for my old K20??? Suspension's stock.
    I tought of all terrains also but i think they not quite as good as mud terrains right?:confused:
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    thats like a skinny 31 size.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    When I had a '77 K20 I went with a 2.5 lift vs. the stock springs. It improved the ride quality 100%, stoped the front end from bottoming out going over RR tracks etc. I had no problems running 33's with the little lift.
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    It will rub a little on the corners of the front wheelwells when you flex or back turning, but just a little.
  5. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I had a set on my k20, fit fine. No lift:o
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no lift required 235 85 16 came on k20 new back in the day
    very common
    good luck
  7. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    When I put the Rancho EZ ride 2.5" lift on my '77 K20 it was to improve the ride quality and to run 12X16.5s. But the stock front springs were sacked out and if I was going to replace anyways I got a small lift too.
