292cu.in.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gtaft, Aug 24, 2001.
  1. gtaft
    gtaft Registered Member
    Jul 30, 2001
    18
    cordova, alabama
    What's the feeling with you guys on using a 292cu.in. In-line six? Maybe bored a little, put the power on the low rpm side.
    This would be mated to a 208 case with about 3.73's, and 31's. No rocks, just trails and trailers. thanks.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i have nothing against I-6s, lots of low end power, sounds cool.
    scott,
    1989 suburban 3/4t 4" lift soon to be rollin on 33s, tbi350
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    What do you have now?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've had a couple of 292's, and they were great motors. The most recent one was in a C-10 prerunner project I was working on. Check out <a target="_blank" href=http://www.cliffordperformance.com>Clifford Performance</a> for some killer straight 6 power parts.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'v built a couple of six bangers. They were 300 cid ford though. Both turned out real good with lots of power. They were great pullers for 4 wheeling. The last one I built was in my last full size Bronco. It had 9.2 to 1 compression, 4 barrel carb and intake, Headers, and a good torque building cam, Mallory ign and many other mods. It was pretty hot. It sure embarassed many V8s.
    I got most of the performance parts from these guys:http://coloradok5.com/gallery/Thunders-Blaze
    <font color=orange>Charter Member of The Too Much Fun Club</font color=orange>
  6. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    hey i have a 67 gmc p.u with a 305 cubic inch V6 it will pull stumps dude, also you could get a 351 c.i.d. in a 1 ton or larger back then!, i have had a 292 with 5.13 gears 4 speed granny low in a 3/4 ton 71 chevy i used it to pull full size mobile home one time. old chevy sixes are cool out side of that go to a 468 or larger i have a 482 cube in a nova that is pretty quick.
  7. gtaft
    Jul 30, 2001
    18
    cordova, alabama
    I haven't put in anything yet. It will be the 350 or the 292.
    All driving will be under 60mph. Most of the time under 50mph.
    Speed not a factor. Gas mileage is, torque is. Just a buggy for trails and fishing trips. i'll use the 208 tc.
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Under 50 mph and you're looking for mileage? Go with the six.
    In fact, I would recommend the 250. Buddy's 1 ton 2wd w/4.57 gears, 4 spd, and 250 actually gets better mileage than my 2wd 1/2 ton w 305 and auto, 3.42 gears.
    Both the 250 and 292 are great little engines. The 305 V6 is awesome too.
    Call Clifford for sure, they've got everything you need, but stay with the 1bbl carb though, that's what you want for mileage/low torque.
    Lift It, Lock It, LIVE IT!!!
