2lo
Discussion in 'The Garage' started by az84chevy, Jul 7, 2005.
  1. az84chevy
    az84chevy Registered Member
    Feb 17, 2004
    69
    I tried searching but couldn't find anything about this. if i put the truck in 4wd with the hubs unlocked (2lo), will this cause any problems. Didn't seem to when i did it to trouble shoot my t-case but im just wondering if it will do anything long term.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  3. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    nope, x2
  4. az84chevy
    Feb 17, 2004
    69
    cool thanks for the info.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    It's probably wouldn't be an issue, but just keep in mind that you are at least doubling the torque output when in low range. But with it only being in "2lo" all of that torque is being transferred to the rear axle instead of being split between the front and rear. If you were hammering on it pretty hard then there is a much better chance to break something in either the rear shaft or axle.
