2nd Battery on drivers side
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by druehlman, Apr 21, 2003.
  1. druehlman
    druehlman Registered Member
    Mar 25, 2003
    45
    Texas
    Here it goes...
    I would like to install a second battery on the drivers side of my 72 GMC Jimmy but am not sure of the best battery mount to use. I plan on using a hellroaring Battery isolator/combiner. Im trying to keep a clean look under the hood as we all are but I need it to be stout as well. I am curious if any of these trucks were avialable with a second battery option, so maybe one could be found at a junk yard?
    Any way thats all I had.
    Thanks in advance.
    Dave R
  2. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    My knowledge doesn't go as far back as 72 but the 80s K-5s locate the 2nd battery(stock diesel)mirrored on the opposite side of the radiator. You could get the bracket from the wrecking yard for that setup.
    David
  3. druehlman
    Mar 25, 2003
    45
    Texas
    That's were I want to put it but the 1980 hardware isn't compatable with the 69-72 front end, maybe I can adapt the rack to fit. I'm not a big fan of jerry rigging things.
  4. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    hmmm, Ive had this discusion before with other people...I can't prove it with papers or factory option list..but one of 71 blazer parts truck has a driver side battery mount that looks factory in every way...it's stamped the same as the passenger side... /forums/images/graemlins/k5.gif
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
  6. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    David,
    Here goes, the 69-72 did offer a second battery, but it was for the trucks only, it was for the camper specials and it's the $hit if you can find one. It was never offered on the blazers, but obviously the blazers and the trucks engine comp were almost the same.
    The second battery trays are probably one of the most rare options you will ever try to get your hands on, and they are not available aftermarket.
    Your best bet is to try to fab up something with another original tray, or something that will work.
    I have two in my blazer, but I stopped caring about how it looked a long time ago. Mine is strickly a off road blazer and an around town rig.
    Good luck.
    therobzilla
  7. druehlman
    Mar 25, 2003
    45
    Texas
    Rob,
    Thanks, that clears it up, I guess. Do you have any picks of you fab job to give me some ideas. If you could email them to me or post links it would be awsome.
    Thanks agian,
    Dave /forums/images/graemlins/thumb.gif
  8. sanddragon2004
    sanddragon2004 Registered Member
    Feb 19, 2003
    80
    San Jose
    while we are on the subject of second batteries, does any body know where you can get wiring kits for the adding a second battery?
  9. druehlman
    Mar 25, 2003
    45
    Texas
