2nd EGR Vave in 4 months? WTH?
Discussion in 'The Garage' started by cbbr, Jul 26, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Its a 1999 Ford Expedition EB with the 5.4 (the wife's ride). 2nd EGR in 4 months. Why?:1zhelp:
  2. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    need more info for help. lots of times its not the egr valve but a wire or sensor or vac line problem. and some older fords had a gray box with 2 special high temp hoses from the exaust manifold that went bad or the little box went bad. pull lines from the box and look for corossion in the tubes. if there get a new one. if your truck has one.
  3. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Plugged egr passages and/or an inoperative dpfe (the little gray box sweetk30 made reference to) are far more common failure items than the egr valve itself.
