2nd Gen Blazer Gas Tank -------> 1st Gen
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by badpeanut, Mar 22, 2003.
  1. badpeanut
    badpeanut Registered Member
    Sep 16, 2001
    11
    North Dakota
    I've read about installations of the "large" 31-ish gallon 2nd generation Blazer gas tank in a first generation and how they require relocating a crossmember and they reduce clearance.
    How about the "small" 25-ish gallon second generation gas tank? Has anyone put one of these into a first generation? Do they require crossmember relocation and/or reduce clearance?
    Do the 2nd generation factory skidplates work on the 1st generations?
    I want extra gas capacity cheaply (so the nice Aero and NWMP tanks are not an option).
    Wes S.
    '71 K5
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i dont see why a newer one wouldnt go under a first gen, as long as fuel filler diameter is same for hose and if you have later straps and all then i dunno why wouldnt. i know an 86 blazer tank pops rihght in under a 67-72 pickup anyways and the only real difference from pickup to blazer frames is the rear drop down of frame rails for the rear bumper
  3. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    I have a 91 blazer tank under my 72 i had to make my own strapes and i used two 2 inch channel as new cross members so the skid plate would fit it turned out very nice.. <font color="red"> 1 FN HI K5 </font>
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i put a post a while back here listing the parts I used. do a search and see if you find it.
    ARQ.
