2wd 14ff= 4wd 14ff?
Discussion in 'The Garage' started by stockk5, May 14, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Are the 14bolt full floaters the same as a 4wd one? A friend says there is one on a guys parts truck but its only 2wd here, i was wondering if they will bolt up just like at 14ff from a 4wd truck. Thanks Mike
  2. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    The only differences on srw 14bff are on 1 tons. They have narrower spring perch mounts and the shock mounts are in different positions. also, 1 tons use 13 inch drums. 3/4 ton should be 11 inch
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    there are 13" brake, 3/4 ton diffs,,,, i have/had one :D
    also came from a pick-up, it's now on my 1/2 ton Burb.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The only difference between a 2wd and 4wd 3/4ton 14ff is the shock mounts. On the 2wd version, the shock mounts hang down a lot lower. Now if its out of a 1ton, then like was said above, you'd also have to move the spring perches.
