2wd 4l60e Vs. 4wd 4l60e
Discussion in 'The Garage' started by ChickenRammit, Jan 9, 2006.
  1. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    What Differences Are There Between The 2wd And 4wd Versions Of The 4l60e? I Was Just Figuring The Only Difference Is That The Output Shafts Are Of Different Lengths, But A Transmission Guy Started To Tell Me That They Use Different Cases, But I Think He's Wrong. Whats Everyone Around Here Have To Say About This?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    for the same year trannys, yes the outputshaft is the only difference. the 4wd 4L60E did use a K case, but so did some of the 2wd. the difference is the way the inspection shield bolts on and what its made out of. some say the bellhousing is thicker, but the only thickness difference ive seen is where the inspection cover bolts on, it is thicker on a k case.
    in, IIRC, 96, they changed the case to a 2 peice case with a removable bellhousing and an inspection sheild like a manual tranny. the adapter or tailshaft pattern was also changed to what the th400 and 4L80E has. hardly anything internall was affected by this change.
    the output shaft between the 2wd and 4wd has changed from 1982 to now. except that the governor gear is not there on a 93 and newer tranny. there are a few differences between years and models on the 2wd shafts, but the 4wd shafts are identicle.
  3. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    SO, BASICALLY, MY TRANSFER CASE ADAPTER FROM MY 700R4 WON'T MATCH THE TAILSHAFT PATTERN ON MY '99 4L60E? WHERE CAN I GET AN ADAPTER THAT WILL FIT A NP208 ONTO THE '99 4L60E?
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, you should be able to find them on 96 and newer fullsize trucks. the tcase pattern is the same.
