2wd 4wd cabs
Discussion in 'The Garage' started by 86chevybanshee, Aug 11, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    my friend just offered me a mint 82 2wd cab, what are the differences in the 2wd and 4wd cabs?
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    The tranny tunnel in the floor can be lower possibly creating tranny/floor interference problems. If you're using a body lift this wont be a problem. That's the only physical difference I know of.
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    crap, i dont really want to use a body lift, i got a 2inch lift sitting in my shed, maybe i can cut the pucks in half?
  4. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Check around. Early (73ish) models had bolt in tranny humps and then later spot welded. You might be able to find one in a salvage yard and weld it in to the 82 cab.
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    My 74 K20 has a 2WD cab on it(whats left of it anyway /forums/images/graemlins/crazy.gif)--the truck was a 77 but the previous owner changed the cab to a then rust free 74 2WD cab..The bolt in floor hump from the 77 4x4 cab bolted right up to the older 2WD cab,after cutting the solid hump out,and drilling the holes--the hump doesnt fit at the rear near the seat,you will have to fab up a piece of sheet metal to fill the gap--mine was open for awhile,and the heat that gets in the cab thru there is incredible,like a hot air furnace,even in the winter.My truck has a 3 inch body lift,not sure if the transfer case would hit the floor without it.I made a plate to block it off, because mice used it for a handy entrance to the cab,and they ate my lunch I had stashed in the cab one winter day, and some of the wiring harness for desert!. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/screwy.gif
