2wd & 4wd hydro clutch stuff - same?
Discussion in 'The Garage' started by madmike, Jan 30, 2003.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I'm like 95% sure on this, but I'll ask anyway: Is the hydraulic clutch, pedals, and bellhousing stuff the same between 2wd and 4wd models, as long as the SM465 was used?
    I've always thought I was right on this, but I heard something not too long ago that made me doubt myself, /forums/images/graemlins/confused.gif and I know there are some experts here. Thanks!
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    The pedals &and hydro should be same.The diameter of clutch could vary between 2 & 4 by.Larger clutch will usually swap in.Dia. of flywheel makes the differance. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yes, they are the same. Clutch diameter varies on the engine size and capacity of truck. 4.3L & 5.0L are usually 11" clutch. The rest should be 12". Flywheels will accept either size.
