2wd/4wd rear axles
Discussion in '1992-Present Chevy & GMC models' started by Chris_T, Oct 3, 2002.
  1. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    It turns out the pinion bearing on my 94 2wd 1/2 ton is going (gone) and I need to replace it. Rather than have a new gearset installed (don't know how long I'm gonna keep the truck) I was thinking of swapping one of the plentiful 10 bolts available into it. SO my question is - what have I got in a 94 GMC 1500 SLE 2wd? Obviously I have 5 bolt rims, but can I swap my shafts into a 4wd housing? Are the spline counts the same? What do I need to look for? (And if anyone has a 2wd 10 bolt with 3.73's that's a direct swap, please let me know)
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've done this on trucks from the 70' and 80's. The axles swap out great. Dont know about the newer ones. I would think that they would. It would be more expensive to build more parts instead of just swaping axles at the factory.
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I'm going to agree with Sandman on this one too.
    Just to make sure, measure it out. Wheel flange to wheel flange and spring pearch to spring pearch.
  4. correct me if im wrong, but i believe the 2wd rear axels are a little bit narrower than the 4x4 ten bolts.
  5. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    yeah, thats what i thought too...the 2wds being a little narrower.
  6. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    Checked it out on some auto parts sight and yeah, the axles for 2wd and 4wd trucks are different lengths. That said, anyone know where I can look for a complete 2wd rear axle?
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  8. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
  9. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
