2wd 700r4 output shaft
Discussion in 'The Garage' started by 0cP, Jan 11, 2006.
  1. 0cP
    0cP Registered Member
    Mar 7, 2005
    11
    Perkasie PA
    I have a 2wd 700r4 I want to put a tcase behind. Can I just shorten the output shaft or do the splines not go back far enough?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they don't go back far enough
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Just swap the output shaft. A good tranny builder can do it in 30 minutes. I had the output shaft removed from a dead 4WD trans and installed into good 2WD trans. I helped and watched and was amazed at how easy it was. We finished up both in less than an hour and that included some time to look for some gaskets and plenty of chatting. :)
