2wd blazer, font suspension ???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by arq, Mar 17, 2001.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I am thinking of converting one of my blazers to a 2wd, the doner(2wd swb truck) has rear leaf springs on it. that should be an easy swap, i hope. I want to keep the 6wheel lug pattern. The doner only has 5lug. Were/Are there any front 2wd 6lug wheel patterns out there for our generation. also the doner has front disc brakes.
    ARQ.
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Dennis, I've seen a couple of 2WD trucks in the yards that had 6 lug flanges on them. I can't rightly say that I have any clue as to what the difference in the truck would be from one with a set of 5 lug flanges...
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    If its a 2wd and has 6 bolt hubs, then its a drum brake truck, there are no such thing as a 6 bolt 2wd disc brake truck.....
    There are aftermarket 6 bolt rotors made now.
    About 130 bucks a pair,....
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", Olive green and primer, rusted out, rice smasher!
  4. 72lowblazer
    72lowblazer Registered Member
    Mar 8, 2001
    10
    Annville, PA
    From what I am told, it is pretty straight forward. There is only one bolt that doesnt line up. I am planning on doing this, but I am converting the back to coil. By using the mid section and trailing arms out of a pickup as well.
    72 k5 Blazer 307/3pd on tree, posi rear (one of my projects
    69 Chevy Pickup currently being put together
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    thanks all,
    I did want to do a strait out conversion from 4-2wd but wanted to keep the 6lug disk in front.
    ARQ.
